Old 02-21-2015, 06:47 PM   #1
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Default Ring and pinion set up question
I'm setting up a new set of Motive pro gears in my 12 bolt,the pattern is out towards the heal of the gear. Do I need a thicker pinion shim or thinner to move in towards the toe? Right now it has a .016. Thank you.
Dana Fitzpatrick is offline   Reply With Quote
Old 02-21-2015, 07:18 PM   #2
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Ring and pinion set up question
Try a .030-.035. That was where the Richmond pro gears usually were.
Greg Hill 4171 STK
Old 02-21-2015, 08:19 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Dana,
What ratio are you installing?
As posted above, a pinion shim of .032 - .033 will almost always be good with a 12 bolt.
Larry Woodfin 471W
Old 02-21-2015, 08:41 PM   #4
Dana Fitzpatrick
They are 4.56's. It's a Strange housing,could that make a difference?
Looking at an old Richmond gear instruction book I have, the pattern looks like one they show as having "low tooth contact,heavy in the root of the drive gear.Move the pinion out of the gear mesh,i.e. increase the pinion cone setting.Translation, please, Lol.
My present pattern doesn't look quite as low on the toe side as their drawing,though.
Old 02-21-2015, 09:05 PM   #5
pbp1
Liked 27 Times in 6 Posts
Moving the pinion in or out will not change the contact pattern from heel to toe, it will only move the pattern deeper into the root of the teeth or out toward the top edge of the tooth. Heel to toe is mostly affected by the cut of the gear and the alignment of the pinion bore machining to the carrier bearing bore. What you are looking for is the pattern to be centered between the root of the tooth and the edge of the tooth with a rounded edge on the pattern and not a pointed edge on the pattern.
pbp1 is offline   Reply With Quote
Old 02-21-2015, 09:30 PM   #6
Dana Fitzpatrick
The pattern does come to a point at the root side of the tooth. Not at all bullet shaped. I did increase the pinion shim to .022. It was .018, not .016. How do I get rid of the sharp point? Back lash is set at .008-.010. The ring gear is marked .008 from Motive.
Old 02-22-2015, 07:45 PM   #7
Greg Reimer 7376
Liked 704 Times in 218 Posts
Cool Re: Ring and pinion set up question
Back in the bad old days,I was a line mechanic at a few Chevy dealers. There were still quite a few 12 bolt equipped cars running around out there then, and it seemed that the lower the gear, the thicker the pinion shim needed to be for a good set up. OEM stock gear ratios, 2.73-3.73's seemed to like a .030"-.031" shim, 4.10-4.88's all seemed to like an .032" shim,5.38's and 5.57's seemed to need an.032-.033", and insane ratios like 6.14's might want an .034-.035. .008-.011 on the backlash seemed to be optimal,as well.You are right in the center of the infield with the dimensions you mentioned, but you didn't state what gear ratio you are using. This info should get you started.
