Liked 124 Times in 44 Posts
Who's weather station and soft ware is everyone using?
Liked 275 Times in 76 Posts
Altronics Performaire PC w/pager and Crewchief Pro. You may want to clarify handheld or trailer based style. Pager or no pager as well.
Sean
I'm not sure about trailer or hand held. Right now I have none. Looking for advice.
Liked 79 Times in 22 Posts
Liked 237 Times in 126 Posts
I have an app similar to the one listed by Greenlight. It's OK, but you have to enter all the weather info by hand if you don't have an Internet signal. If you do, it uses data from a location other than the track. Usually the nearest airport. Not technically a weather station.
Dale |
Apps IMO are fine if you are not wanting accurate reliable information track to track. By using the same gauge be it analog or digital for weather, or tire pressure it is repeatable. If you are looking at information from location X, and then you race at a different track that your information is from Y. It may not be much, but did the car pick up or slow down from weather or ? Just something to think about. How close are most airports to the track, if that is where this information is coming from it makes a difference.
Sean
