Old 11-29-2014, 10:06 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default handheld air "inflator" for use in lanes
I see racers using a handheld air "inflator" that is shaped somewhat like a drill. Does someone have experience with a handheld unit for adding a last minute 1/4 pound of air?
Larry Woodfin 471W
Old 11-29-2014, 10:25 PM   #2
SSDiv6
Default Re: handheld air "inflator" for use in lanes
The search feature is your best friend! ��
http://classracer.com/classforum/showthread.php?t=23887
Old 11-29-2014, 11:45 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I've got one of the Bickel compressors Larry. Be sure to test it beforehand on your tires...it won't actuate the valve in some stems. Worked fine for airing up the air bags on the truck, but when I got to the track I could not air the tires on the car. Guess who didn't bring the air tank that day? Took everything I had not to heave it across the pits lol...my air tank now goes along everytime if only for the ride. I really can't recommend the Bickel inflator. What we should be using if there is a definite need... https://www.biketiresdirect.com/search/co2-inflators
Rich Taylor
I/SA - 321
Old 11-30-2014, 12:51 AM   #4
Robbie Draughon
Liked 29 Times in 5 Posts
I use a craftsman 18v from Sears. Batteries interchange with my drill. I've had it for a few years with no problems.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
Old 11-30-2014, 08:47 AM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: handheld air "inflator" for use in lanes
I've always used a little manual foot pump. It's smaller, lighter, less expensive and plenty good for that 1/4 - 1/2 lb by hand. The gauge is irrelevant since I double-check with my regular tire gauge. The plastic chuck is pretty cheap, but I eventually replace it with a better hose & metal chuck. You can find them anywhere - Harbor Freight, Walmart, etc. & cheap enough to have a spare!
As small as it is, I have been warned a couple of times over the years about keeping it secured in a box to keep it from being a "projectile" in case of an accident.
http://ecx.images-amazon.com/images/...500_AA300_.gif
LOCOMOTION Racing
Old 11-30-2014, 10:15 AM   #6
Dragsinger
Myron, I like the manual idea.
Larry Woodfin 471W
