Old 11-20-2014, 05:26 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Roller Rockers on LT-1
Going to install Roller Rockers on the LT-1. Also, planning on going to head studs since I have the motor apart. Somewhere I read/heard that there are potentially interference issues when using roller rockers with studs.
Any input/wisdom/solutions on this issue....if one exists.
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 11-20-2014, 06:43 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Roller Rockers on LT-1
Shouldn't have any clearance problems with the rockers to head studs, I would recommend the 12 point nuts. If you are going to hone the block (recommended), make sure you do it with the studs installed first. Using the studs with torque plates to hone the block.
Old 11-20-2014, 06:53 PM   #3
tj310
You'll want the 12 point nuts in the centre 4 locations between the springs for wrench clearance. I also ground a couple of threads off of the studs in those locations so they didn't scrap .---Trevor
Old 11-21-2014, 12:45 AM   #4
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
I found it necessary to use adjustable guide plates to maintain proper alignment.
Jon Sarrett is offline   Reply With Quote
Old 11-21-2014, 09:36 AM   #5
Lee Valentine
Liked 319 Times in 68 Posts
You might want to rethink head studs on an LT-1 stocker if ever go to tear down, a little tight getting the heads off in car.
Lee Valentine 1661 STK
Old 11-21-2014, 10:49 AM   #6
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Just be sure to check your cam lift with roller rockers. Just because they say 1.5 doesn't mean they really are. Comp cams stainless steel rocker arms are some of the truest to size.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
