Old 09-02-2014, 05:49 PM   #1
FINESPLINE
FINESPLINE's Avatar
Default Ignition wires
Any recommendation for ignition wires. Using an MSD 6 AL plugged to a MSD billet distributor w/ HEI hat. The more you read, the more confusing it is. Thanks in advance.------John
FINESPLINE is offline   Reply With Quote
Old 09-02-2014, 06:20 PM   #2
Liked 1,909 Times in 427 Posts
Default Re: Ignition wires
Had good luck with Moroso 40+.
Old 09-02-2014, 07:33 PM   #3
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
MSD 8.5 mm Super Conductor (I too use a 6AL with the Billet MSD distributor, BBC high 9 second ride)
Old 09-02-2014, 08:04 PM   #4
FINESPLINE
FINESPLINE's Avatar
Well , I guess I am on the right track as those two sets of wires are my picks so far. Anybody have any experience with the Granatelli wires ? Read an article on them. Almost to good to be true----of course ! Read some comments on an ignition wire -------not so good . I guess the basis of comparison is
ohms per foot.
Old 09-02-2014, 08:14 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Like all race car parts, your experience with other racers favorite parts may vary .
Keeping that in mind , I've had excellent results with the Moroso 40's . Treat them well , keep them clean and away from the headers ,and they will last several years.
I had old Moroso 80 ohm wires on my car for at least five years with no problems and only replaced them when I was chasing an ignition box problem.
Spend the money on the sleeves, well worth it.
Old 09-02-2014, 11:10 PM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Had Accel 8.8 wires on my car for the first 2 years then installed my data acquisition system and had all kinds of noise issues on the rpm channels. I called Computech and they suggested MSD 8.5 wires and sure enough the problem went away. Cut to fit is the only way to go for a clean look.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-02-2014, 08:10 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Ignition wires
I've been using Accel 8.8 300+ race wires on my car for many year to compliment the Mallory Hy-Fire 6AL ignition box, coil & billet distributor. I buy the cut-to-fit wires to minimize any excess length and route them in a convenient path. Wires are changed every several years as preventive maintenance. They never gave me a problem. Only had a minor distributor wire connector problem once with the rest of it. Otherwise, its pretty much been install & forget!
LOCOMOTION Racing
