Liked 205 Times in 93 Posts
couple slightly seeping @ the nut. any remedies?... please/thankyou.
http://classracer.com/classforum/sho...ing+head+studs This should help. ---Trevor
Liked 320 Times in 102 Posts
We always used the GM brown sealer in the can with the applicator attached to the cap....
It looked like Permatex Aviation Form-A-Gasket only thicker..... Nasty stuff but it worked great on studs and bolts.......... Bob PS: Don't forget to add a good block sealer such as Moroso Ceramic Block Sealer or K & W Metallic Block Sealer
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 08-27-2014 at 02:04 PM. Reason: add PS |
Liked 30 Times in 17 Posts
Richie,
Always found that on studs it helps to actually put some of the sealer in the threaded hole first. Not sure why it works, never do it with bolts ? If you are fixing it without pulling the head, pull the stud completely out, get some sealer down in the hole with a screwdriver or something and then thread the stud back in.
Bill Koustenis |
