Liked 21 Times in 13 Posts
Building a 1970 challenger and working on front suspension, and would appreciate some advice. First the old direct connection books recommend an .840" dia torsion bar, which as far as I can tell isn' t made anymore, or if it is, it's pricy. I'm considering turning down my originals to that diameter. I can't think why that wouldn't work. Thoughts ? Question 2, strut rod bushings. I've read the previous posts on it, and I didn't see a consensus on bushing/bearing. I'm looking for a good working suspension, not the most expensive solution. I do all my own work and can fab most anything. Thanks in advance.
Brian
Brian Carpenter Stock 1358 |
Liked 2 Times in 2 Posts
Contact Firm Feel
http://www.firmfeel.com/b_body_mopar_torsion_bars.html They make an .820 drag racing torsion bar. If they are a little pricy then look for a 6 cylinder bar for an e-body. I don't think it would be a good idea to turn down a torsion bar. You would ruin the integrity of the properties of the bar itself and it would probably snap under load like coming down from a wheel stand. Just my two cents.
Fred Palumbo 1025 STK |
B and E body, same torsion bar...B-body might be easier to find with a slant 6
Liked 279 Times in 68 Posts
Larry Hill posts on here all the time. He has a 70 Cuda that works pretty well. Send him a pm, he might be able to help.
Greg Hill 4171 STK |
Thanks all for the tips, I'll PM Larry. Any other ideas, please post or send a PM. thanks
Liked 10,939 Times in 2,259 Posts
What combination do you plan to run. Weight will determine how much stored energy you will need to transfer the weight to the rear tires.
