Old 07-21-2014, 09:53 PM   #1
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default I want big wheelies
My car is running about as fast as I'd expect now, but it only gets a few inches of air under the tires and that's just not gonna cut it for me so let's hear some ideas, eh?
60 foots are 1.50-1.53. 327/275, Advanced clutch, 5.38 gear, Jerico w/ 3.19 low. Car weighs 2915 with driver, no ballast, on a 2910 minimum for E. Calvert split monos, 1 step lower than stock. Rancho RS9000 rear shocks set full stiff, Calvert front shocks. Old 6 cylinder springs with I think 1/2 coil cut off. Del-A-Lum bushings in control arms. Eddie Rezac linkage kit for zero bumpsteer.
Paul Merolla is online now   Reply With Quote
Old 07-21-2014, 10:17 PM   #2
Default Re: I want big wheelies
How do your incrementals compare with a fast small block E/S car?
The 60' is about where I was running with a mediocre F/S 69 Camaro 255/350.
You can soften the compression damping those rear shocks some.
You can loosen the extension on the front shocks some.
Old 07-21-2014, 11:02 PM   #3
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Launch RPM?
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-21-2014, 11:14 PM   #4
Paul Merolla
Alan, I'm not sure how the incrementals compare - I'll do some research at Topeka this weekend. I kind of posted this tongue-in-cheek, but I'm curious nevertheless. The front shocks are not adjustable, and the rears only on extension.
Maurice - I've left at 5800 and 6200 with no noticeable difference in 60'.
Old 07-22-2014, 12:16 AM   #5
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Me too...
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 07-22-2014, 07:12 AM   #6
Liked 10,941 Times in 2,259 Posts
Have 52% or more on the back wheels.
