Old 07-03-2014, 11:50 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default ''Chiller Question''
Do you put the hose hook-up/manifold on the bottom or top rad hose? It would seem the bottom would be more efficient, but the top would be easier access.
J.R. Haddad is offline   Reply With Quote
Old 07-04-2014, 09:13 AM   #2
james schaechter
Default Re: ''Chiller Question''
We put ours on the top. Easy to use and we can chill to 55 degrees if we want to
James Schaechter 3163 STK
Old 07-04-2014, 10:01 AM   #3
FED 387
Liked 335 Times in 182 Posts
what ever is most convienent access!!! if you have a circulating pump it really makes no difference as the water is moving thru the cooling system anyway--FED387
Old 07-04-2014, 09:14 PM   #4
J.R. Haddad
Thanks guys.
Old 07-05-2014, 09:23 AM   #5
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
On our Yates headed motor we go directly into the front of the heads since we have no upper water fill. I have seen some that had it hooked directly to the radiator as well, I would imagine it was a custom piece...
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
