Old 06-16-2014, 08:55 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default Steel rod life expectancy
Anyone using steel rods to 9000 RPM (give or take) with 300 plus runs?
I lost a rod this weekend, ( Howards aluminum ) although the damage was basically just the block , 1 piston..........., Now I'll put a spare block into service and consider steel rods..............but , I'm not about to spend 3-4 grand on a set of Carillos.........no way. I'll go back to aluminum , possibly. I think any rod manufacturer that tells you their aluminum rods will see 300 runs in a combo like mine is full of shee-ot.
My fault / stupidity for running them past the 80 -100 runs ..........I should have chucked them a month ago........I'm a slow learner......... But my best guess is I didnt have more than 125 runs on those rods.
Small Chevy , 14.0 comp 6.150 rod.........so you can do the math , the piston isn't heavy.........
Old 06-16-2014, 09:26 AM   #2
SSDiv6
Default Re: Steel rod life expectancy
Whomever said you could run an aluminum rod for that many runs was full of it. Fatigue and detonation are the worst enemies of an Aluminum connecting rod.
If you select the right brand and material of steel connecting rod, it will go that many runs down the track. One of the biggest factors in longevity is to select the correct rod bolt. My preference is also an "I" beam over the "H" beam style of rod. The steel rod will also allow you to run a tighter deck since they don't stretch like Aluminum rods do. Pro Stock and many Comp guys are currently running steel rods successfully.
Some of the companies I would recommend are Carrillo, Crower, R&R and Oliver. I good set of steel rods from these vendors will not cost you $3000.00 to $4000.00.
Old 06-16-2014, 09:51 AM   #3
joespanova
Not bashing...just repeating the comment the guy shared with me..........nice sales tactic indeed.........but we know better don't we...
It was either MGP , GRP or R&R.
Old 06-16-2014, 11:46 AM   #4
SSGT Mustang
Liked 204 Times in 54 Posts
You can buy a used set of Carrillo or Lentz rods from a cup team for next to nothing (couple hundred bucks).
I had a set of used super speedway Carrillo's in a 9200 RPM 358 and put countless passes on them with ZERO problems. I even dropped a valve, and the rod didn't miss a beat. I sold them to a friend of mine who still uses them in a bracket motor.
I moved over to Manley aluminum rods and broke one after 18 passes. I have GRP rods in a new motor, but am thinking about going back to a steel rod or moving up to a titanium rod, because aluminum rods seem to be ticking time bombs (much more so than a good steel rod).
A lot of guys use aluminum rods, and don't mind the maintenance. I'd rather have an engine that can suffer some "miscalculations" and requires fewer teardowns.
Just my .02.
SSGT Mustang is offline   Reply With Quote
Old 06-16-2014, 11:53 AM   #5
SSDiv6
You can purchase a set of Crower Billet Rods Maxilight #5 (800+ HP) or Maxilight #6 (1,000+ HP) steel billet rods with the Honda rod journal and custom length size for less than $1600.00 and it includes free shipping.
Old 06-16-2014, 12:23 PM   #6
joespanova
The used speedway stuff , that would be hit or miss.........still make me nervous after all that abuse. Not only that....I wouldnt have a clue as to who to call.
I'll look at the Crower stuff and call.
Old 06-16-2014, 04:32 PM   #7
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Aluminum is a terrible material for fatigue resistance. Horrible.
A quality steel rod (not made in China) will last essentially a lifetime if kept within its design range. Not so with aluminum no matter what the alloy, or QA/QC. Its just the nature of the materials inherent poor fatigue resistance qualities.
Oliver and Manley offer very reasonably priced 100% USA material, USA forging, and USA machined rods... right around $1200 a set.
Old 06-17-2014, 08:01 AM   #8
Bobby Lundholm
Liked 129 Times in 51 Posts
Give me a call I work at Oliver Racing Parts I'll work with you. We've had customers call that had 10 years on set of rods in 2,500 HP blower motor. Oliver is the only company that every part of the production process is done in the USA to be exact everything is done in Michigan.
231-237-4515
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 06-17-2014, 08:18 AM   #9
joespanova
231-237-4515
Will do. I'll call this afternoon.........
Thanks
Old 06-17-2014, 09:02 AM   #10
SSDiv6
231-237-4515
Oliver makes one of the best steel rods I have seen.
Some of the Ford off road racing trucks have used their rods for 3 seasons without failure.
