Old 06-10-2014, 08:33 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Tire Pressure
I need a starting point for rear tire pressure. 1991 Camaro, J/SA,
Hoosier Radial, 9 x 30, C06,18209. "8 Rear Wheel.
Thanks in advance for your help. J.R.
J.R. Haddad is offline   Reply With Quote
Old 06-10-2014, 08:58 PM   #2
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Tire Pressure
20lbs. is a good starting point. You can probably run more than that but 20 is where I would start.
Greg Hill 4171 STK
Old 06-10-2014, 08:59 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
I would start at 20 and go up till it spins. You should be able to run up to around 25 if the car works as it should. I would probably shoot for the 21-23 range for a normal pressure.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 06-10-2014, 09:47 PM   #4
J.R. Haddad
Thanks guys. J.R.
Old 06-11-2014, 01:17 AM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Been running 18psi so far without issue...never tried higher.
Rich Taylor
I/SA - 321
Old 06-11-2014, 08:00 AM   #6
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Depending on the track I average 21lb...
What does your car 60' at?
Old 06-11-2014, 12:08 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Tire Pressure
I run 21 lbs but on a 10" rim. A narrower rim may require less to get a full width footprint. Car weight and how hard the suspension works are also factors.
LOCOMOTION Racing
