Hi all!
I am Matt with PAC Racing, some of you may know me or have talked to me. I am looking for some feedback/help from you guys. I have thrown around the idea of doing drag springs for stock, super stock and anyone who races a class that needs an OE style spring. My question is, is there a need for us to start doing stock style suspension springs? Is there already a great line out there that does not need improving? If there is not, what needs to be done? Any help ideas would be great! Thanks! |
Liked 541 Times in 112 Posts
Matt: A lot of guys are using Moroso "Trick" Springs. Just take a look at their catalog and you'll see a listing. Question for you, why did PAC "supercede" the PAC1409 beehive? I used the PAC1409 with great success and you guys replaced it with the PAC1409X, which has a significant amount more seat pressure. Thank you.
Jim Kaekel 3836 STK |
Liked 38 Times in 9 Posts
And invariably the ride height with the Moroso springs isn't right, so you have to cut them...and then they don't fit the pockets correctly...unless you cut a full coil at a time...
Yes Matt...there is room in the marketplace for an affordable series of springs to fit most popular applications. The Moroso line is a good place to start... PM me if you want to discuss further... |
Tim,
This is the info I am after. It seems Moroso's "trick" spring is the go to spring. At the same time I hear so much negative feedback. We are searching for a product line that works the way it is supposed right out of the box. Now you did mention affordable. What is that? Our stuff would range in the 70-100 range more than likely. That is per spring too. Thanks, |
Jim,
I will have some discussions here and see what we can do to help you out. Thanks, |
Matt,
I can't speak for anyone other than myself...but I would gladly pay $70-100 per spring for something that works the first time. Tim |
We decided to go with the "X" only series due to its additional processing over the standard 1409. The loads should only be 15lbs more. In all honesty, most people like the extra 15lbs. Are you having issues with the extra load? If we have enough people complain we may do a low load version that would bring it back to 150 @ 1.800".
Thanks, |
I know what they are advertised as, but It's more like 20-25 lbs. more in actuality. I called and talked to Jason from your company about this in early April. Please bring back the original PAC1409. Thank you.
