Looking opinions on which casting is the best for a SBC 350.... Any insight would be greatly appreciated
Liked 18 Times in 10 Posts
Liked 285 Times in 87 Posts
Carl… We've found the "386" and "388" blocks to be good also. They are usually Early 1968-69 castings, prior to the "010". The early 1969-70 "010" are very solid also, and in most cases have a "K12" behind the passenger cylinder head at rear of block. Always consider core shift that is noticeable at cam tunnel, try and find a block that has the cam tunnel bored centred with the thrust flange. Good Luck…MB.
#4 | |
I should also add if you can find an 010/020 with 2482 on the center caps, Don't go by core shift as a sonic test is the only real way to tell if you have proper cylinder wall thickness. I have about 40 blocks that show no core shift but have failed a sonic test and have seen many blocks that show a ton of core shift but the cylinders were fine. Most blocks I have failed is because of one thin cylinder. |
Liked 32 Times in 19 Posts
What about the Bow tie blocks? Anyone found another manufacturer which is accepted ?
Does the Dart SHP meet the criteria ?
