Old 12-30-2013, 08:03 PM   #1
Lyn Smith
Liked 1,002 Times in 203 Posts
Default 305/350 crank
Got a street 305 Chevy im rebuilding.It had a bad crank,so I came across a 350 crank which is the same stroke.Can I use the 350 crank ,or will it have a balance problem?Dont really want to spend the money to balance it. thanks
Old 12-30-2013, 08:33 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: 305/350 crank
Lyn,
The 350 and 305 cranks that I have done have been quite a bit different in balance. If you are replacing pistons it seems like they are making even the stock replacement pistons a lot lighter so that will make the problem even worse.
I would say it would be worth having it at least checked. You probably don't have to do the entire balance job, making all of the rods and pistons the same weight etc. Just use one of the 305 assemblies as a reference to make the bobweight.
Hope this helps,
Bill Koustenis
BillK is offline   Reply With Quote
Old 12-30-2013, 08:51 PM   #3
Rob Petrie E395
Liked 216 Times in 77 Posts
I cant say for sure what a 350 crank in a 305 will do. But I know for a fact that a 305 crank in a 350 will vibrate at around 2500-3000 RPM. Bad enough that you will take it back apart.
Old 12-30-2013, 09:23 PM   #4
Steve Williams
The 305 crank with 350 rod-piston is a problem. The 350 crank with a 305 rod-piston is not a problem. No balancing required for a stock piston or cast replacement. The 305 crank is the nastiest piece of junk that is associated with Small Blocks IMHO.
Steve Williams is offline   Reply With Quote
Old 12-30-2013, 10:02 PM   #5
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Dont forget the 262 and 267 ci motors as candidate for piece of junk award
Old 12-30-2013, 10:26 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
305-350 cast cranks were the same casting number and the only difference was the factory balancing. If I recall correct the casting number was 448...last 3 and if you look at the depth of the holes on cranks from a 305 vs a 350 you wll see a big difference in hole depth....the 305 bobweight was lighter so the crank had deeper balance holes drilled.
You could use either crank in either engine but needed to address the balance issue......
There is no difference in the counterweight overall diameter that I can ever recall....
Rich Biebel
S/C 1479
Stock 147R
Old 12-31-2013, 08:51 AM   #7
BillK
Steve,
Other than the balancing there is absolutely no difference between the two crankshafts.
I just looked through some old balance cards and found a 305. The piston and pin was about 60 grams lighter than most of the stock type 350's I have done. 622 grams compared to 682 for the 350 If that is not enough to make you believe that the 350 crank needs to be rebalanced to use in a 305, then I don't know what is
Bill Koustenis
Old 12-31-2013, 10:17 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
267,305,350 all are same crank, EXCEPT for balance,you can identify them by comparing counterweights,267 will have deepest holes,305 a little less, some 267/305 cranks have notches cut in counterweights to remove weight.
I would at least try to find 305 crank, or balance the 350 crank,I balance everything,be surprised how good a 3.5 briggs will cut grass when balanced,took 2- 3/4X3/4 pieces of heavy metal.
Might get someone to balance w/bobweight made up from 1 piston/rod.
Mike Taylor 3601
Old 12-31-2013, 10:31 PM   #9
Steve Williams
Originally Posted by BillK View Post
Steve,
Bill,
The differences go further than just balance. The use of a 350 crank in a 305 has been done several times in our shop and with a cast replacement piston, I never sent one out for balance. The advice of my crankshaft guy was that 305 cranks rotating 350 rod-piston was a problem, but 350 crank in 305 with cast piston or cast replacement was not a problem provided it was a stock rebuild, stock intended RPM range. As far as the weight difference between the two engines, I don't recall what the exact number was, but it seemed it was much closer than 60. I want to say it was 46 or 48. I can tell you that the 305 crank, if used in a 350, will have a bunch of mallory in it. Built one for a customer who supplied this balanced assembly. He knew nothing of what the crank was until we looked it over closely and told him. The amount of mallory was a dead give away that something wasn't right.
