Old 12-01-2013, 11:08 AM   #1
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
Default Stocker info needed
I have a 68 chevelle wagon with a BB in it (not stocker legal) and im thinking about turning the car into a stocker. How do I find out what drive train combo I can run? I tried looking it up on NHRA.com but my head was spinning. Im curious as to what class letter I can run and options, weight, ect. Not looking for saftey of modification fules as those are easy to figure out, just looking for possiable combos. Thanks in advance.
H.A.A.C. Racing is offline   Reply With Quote
Old 12-01-2013, 11:14 AM   #2
CJ Perry
CJ Perry's Avatar
Default Re: Stocker info needed
Depends on how much you want to spend. I'm pretty sure the first thing is you need to find out what the factory shipping weight of the car is. Once that is clarified you can find out what the car naturally falls in. I would say a good B/C SA class. Combos can be the sky as the limit.
Just noticed the "wagon" part. I would say its going to fall a little higher than the B/C SA class.
CJ Perry
9931
PCA-1
CJ Perry is offline   Reply With Quote
Old 12-01-2013, 11:28 AM   #3
Billy Nees
Liked 7,729 Times in 1,739 Posts
If I were doing a 68 Chevelle wagon, I'd be doing one of 2 excellent 327 combos, 250 horse rated at 245(natural M or N depending on trim) or 275 horse rated at 265(natural K or L).
Billy Nees 1188 STK, SS
Old 12-01-2013, 12:10 PM   #4
HR9121
HR9121's Avatar
You probably should take a look at the classified section, there is a 69 wagon for sale for $6200. You probably would have a hard time getting yours converted to stocker trim for that price.
James Williamson
W200 J/SA. SS/JA
Old 12-01-2013, 01:11 PM   #5
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Go to this page, the NHRA Stock Car Classification Guide, then click on 1968 Chevrolet:
http://www.nhraracer.com/content/gen...635&zoneid=132
That will list all legal combinations for 1968 Chevrolets for Stock Eliminator.
WHen you see this
327
250hp
12.88
One * is the Stock Eliminator rating; two ** is for Super Stock. 12.88 is the weight break for the car, which would be J/S with a four speed, and J/SA with a Powerglide/automatic.. A car can move up (I) or down (K) one class, with weight changes. Top weight break (12.00 for I, 12.50 for J and 13.00 for K) x the NHRA Rating of the engine (that 250 hp version 327 I listed is NHRA rated at 245 that you see when you scroll to the bottom of that column) + 170 (driver weight; all cars use 170) = minimum eight, with driver, across the scales at the conclusion of the run. So for J, 12.50 x 245 + 170 = 3,232.5 pounds for J/S-J/SA. You figure the weight the same way for I and K, using that Class' weight break.
For engine specs, camshaft, compression, valves, etc etc, refer to the NHRA Blueprint Guide, at http://www.nhraracer.com/content/gen...634&zoneid=132
Old 12-01-2013, 01:44 PM   #6
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
It's a station wagon he is working with...his factor will be in the 13 - 15 range.
Rich Taylor
I/SA - 321
Old 12-01-2013, 05:39 PM   #7
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
That's a good price if it will run under the index.
Might put a strain on a trailer tho.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-01-2013, 06:14 PM   #8
HandOverFist
Would be around 3700lbs at it's heaviest.
Rich Taylor
I/SA - 321
