Old 10-09-2013, 11:16 AM   #1
Darcy Clarke
Liked 529 Times in 36 Posts
Default 1965 GTO Stick car what slick?
I have a friend with a 1965 GTO stock car that weighs 4050 lbs with a 700hp big block and a tremec with a 4.30 gear what would be a good radial slick?
Darcy Clarke
6254 A/SA SS/JA
Darcy Clarke is offline   Reply With Quote
Old 10-10-2013, 06:32 AM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: 1965 GTO Stick car what slick?
Hoosier 30.0'' x 9.0'' - 15''
Old 10-10-2013, 08:12 AM   #3
Rich Guido
So those are a radial? Thanks!
Rich Guido is offline   Reply With Quote
Old 10-10-2013, 01:50 PM   #4
Liked 5,135 Times in 1,958 Posts
Tremec? As in Stick shift? You don't want a radial .
MT stiff sidewall stick compound
Old 10-11-2013, 11:54 PM   #5
Rich Guido
Thanks Mark!
Old 10-12-2013, 10:09 PM   #6
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
3056ST M/T to be exact ya'll
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 10-13-2013, 08:45 AM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by mark yacavone View Post
you don't want a radial
this^^^^
Old 10-13-2013, 11:37 AM   #8
FINESPLINE
FINESPLINE's Avatar
Stepping away from what type of racing slick to use, I have a question ?Is the TKO600 stock ? If it is you may find anything over 6500 rpm, shifting will become a problem. I went through that problem with mine. If you go to the Liberty transmission site they have a few modifications that will alleviate the problem and extend the life of the trans.There are a few ways to go depending on whether the car is street/strip or just strip. I have my trans sync in 1st and 5th and face plated 2nd ,3rd and 4th. I drive on the street to car shows and on the highways longer distances with absolutely no problems and when you decide to turn it loose it shifts fantastic. Best to call and explain your situation and use and they can best explain what they have to offer.
FINESPLINE is offline   Reply With Quote
