Liked 72 Times in 36 Posts
What is the correct TIG wire for welding 4130 tubing ?
Thank You Kenney Kelley |
HI Kenny. The wire that any welding supply store would recommend is 70s-2. If your tiging .065 wall tubing. I would use 1/16 thick. At about 70 amp's setting.
steve
Steve Tucholsky |
I use ER 80S-D2 and ER70S-D2. Some guys I know even use 308 Stainless filler.
Thank You for taking time to answer my Question.
Kenney Kelley |
Liked 529 Times in 36 Posts
The correct wire is actually ER80S-B2 which is 11/4 CR 1/2 moly same as 4130 tubing the D2 is 1/2 moly and S2 is for Mild Steel only.
Darcy Clarke 6254 A/SA SS/JA |
Liked 345 Times in 149 Posts
ER80S-D2 or ER70S-6, 1/16" for most work.
.045 wire for thinner metal and 3/32" for heavier stuff like rear ends & 4 link brackets. |
Liked 8 Times in 3 Posts
