Old 08-03-2013, 06:07 PM   #1
art leong
Default Timing belt strech?
Can a timing belt stretch enough to retard the cam timing 8 degrees?.
I was putting my motor together. And it seemed that I couldn't get enough tesion on the timing belt. I put another (used) belt on, and it was much tighter. I checked the cam centerline and with the different belt. The cams were 7 degrees advanced (before adjusting).
Can timing belts stretch that much? Or did I make a mistake when I put them in last time?
Art Leong 2095 SS
Old 08-04-2013, 01:23 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Timing belt strech?
If that is the belt that got soaked in oil when the filter let go, yes. Oil or any solvent style cleaner will soften most timing belts. An oil soaked belt is not your friend, even (esp) if you clean it with solvent or brake clean.
Adger Smith (Former SS)
Old 08-04-2013, 01:24 AM   #3
SSDiv6
Liked 1,538 Times in 575 Posts
Hi Art,
My experience with timing belts is that the correct belt will not stretch that much.
I always try to use Gates brand timing belts whenever I can.
As a matter of fact, Gates has a line of racing timing belts and they do make one for your race car under part number T245RB.
Old 08-04-2013, 05:44 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
[QUOTE=art leong;393318]Can a timing belt stretch enough to retard the cam timing 8 degrees?.
QUOTE]
Yes. The race belts referred to in the thread do not stretch as easily, but they all stretch. As do cam drive belts.
Old 08-04-2013, 09:51 PM   #5
art leong
I was (and still am) using the Gates Blue racing belt. The one I suspect was brand new a year ago. I replaced the one that was on there as a "just in case". I put the one I took off a year ago, back on. And had to retard the camshafts 7 degrees to get them straight up (where I started last year).
Tomorrow I'm going to measure the belt that I took off against a used stock belt. A see how much difference there is. I would normally put the original belt back on just to recheck it. But the arthritis is really bothering me (if the pain gets better in the next couple of days I probably will).
Here's a pic of the front of the motor.
Art Leong 2095 SS
