Liked 7 Times in 7 Posts
I know I asked this before...but am getting old and forgot.....
WHICH is better way? Smaller lobe lift and LOTS of rocker arm ratio.... Larger lobe lift and lesser ratio.... Pros/cons of each way.... Which is more common today? Would running stud-mounted rockers dictate pretty much what could be done? (ie...ratios above 1.65 not available for stud mounts...) Combo is 283 Chevy....on a budget...with the stud-mounted rockers.... |
Liked 99 Times in 49 Posts
The trend has been bigger cam or lobe lift and less rocker ratio. JimHanig
budget a shaft rocker system in!
Jeff Lee 7494 D/S '70 AMX |
Liked 1,758 Times in 398 Posts
Get the lift at the lobe not at the rocker. Run shaft rockers. And all the pushrod that will fit.
To let you know how much I believe in what Tim and Billy told me about getting the lift at the lobe, I'm buying a half set of T&D rockers, because I bought 1.75:1 rockers for the intake last time, and I'm going back to 1.7:1. I can tell you that a 1/2 set of T&D rockers are more than 1/2 the cost of a new set. And not by a small amount. If I didn't think lift at the lobe instead of the rocker was important, I'd save myself a ton of cash.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 07-12-2013 at 05:44 PM. |
Liked 739 Times in 135 Posts
And why exactly is this all of a sudden in fashion??
With lower lobe lift, and higher rocker ratio's, a larger portion of the valvetrain mass undergoes lower acceleration. And that is nothing but good. If you can move the lifter, the pushrod and half of the rocker mass less distance and less quickly for a given valve lift and rate, then how can that be bad?? high rocker ratios allow more 'area under the curve' of the valve for a given duration and given cam ramp.. It blows my mind, how all of a sudden high ratio rockers are now out of fashion, and the old ratios are back in.... Perhaps Im missing something, but there is nothing at all technically negative about high ratio rockers other than increased load on the lifter, cam bearings, pushrod, and thus potential pushrod flex,.. And roller cam bearings, large diameter roller lifters, and pushrod quality and design have taken care of that problem.... Tell, you what, its all fine with me, because all I have right now is a set of 1.7's, on the intakes and 1.6's on the exhaust, and I'd like to get some 1.8's, and 1.7's, so this means I should be able to trade someone and even make a few bucks, eh ?? So there you go, all you guys with the 1.8's Intakes and 1.7 exahusts on a SBC jesel shaft, thats OLD SCHOOL.. You are sooooooo lame..... I have what you need right here... some 1.7's and 1.6's.. PM me asap, so you can trade with me, and you can go faster.... |
I'm doing it all wrong. LOL
Ed Wright 4156 SS/JA |
Well...my engine program's not so stable anyhow...so I should be just fine...w/o the
shaft-mounts... Just hoping that the car gets down the track....period! |
#8 | |
I'll stick with what I'm getting from the guys who developed the SpinTron and the guys who use it to refine my valvetrain components. All of whom say that weight/mass on the cam side of the rocker fulcrum is nearly irelevant compared to weight on the valve side.
Alan Roehrich 212A G/S |
