I have a BG 2 port regulator that wont adjust, it goes to 15lb and i cant get it down to 8 or so... is there a fix for it? OR is it worth messing with? THanks
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 461 Times in 111 Posts
Take the regulator and throw it in the garbage. Years ago I ordered a BG regulator and it did the same thing. Summit replaced it and it did the same thing. Sent it back again. Third time, same thing.
68 Chevy11 327 F/S |
Barry Grant was good at marketing. Not so good in the quality control department...
Jeff Lee 7494 D/S '70 AMX |
Thanks Guys...i will not even mess with it... I will put a Holley Volumax on it.. itll work! ITs on my '62 Cat, bracket car...i bought it used , a couple years ago...thought i'd try it... oops!
Liked 529 Times in 107 Posts
I've had one on my car for years, never had a problem (knock on wood). They do require a special inlet fitting that is ported on the regulator side.
Jim Kaekel 3836 STK |
I may have the wrong fitting...im not sure what its supposed to look like...the one i was using, looked like a normal fitting...
