Old 05-17-2013, 04:58 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Ss trans cooler & lines
SS 67/corvette/bbc/TH400 who makes a nice rad mounted cooler and are braded lines/AN fittings required or which type of lines will work and be safe. tks.
Old 05-21-2013, 12:54 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Ss trans cooler & lines
You probably have got no response to this since so few S/SS cars actually run a cooler on their cars.
Most just run a loop on the cooler lines.
If you feel you must have a cooler , look at the ones Derale Performance.
Very strong and efficent ,with pipe thread bosses to use AN or JIC type fittings.
I have my cooler lines for the cars I build made by a shop that makes Hydraulic lines.
Crimped on ends and hose that is made for hot oil and extreme conditions.
The outlet temp from the converter to the cooler can approach 300 deg. ,regular braided hose is not up to the job for the long haul.
Tom Goldman is online now   Reply With Quote
Old 05-21-2013, 02:22 PM   #3
richie 2
thankyou tom, ill check it out. BD DIESEL ive found out make a cooler for the 3/8'' or 5/16'' lines using AN fitting...
Old 05-21-2013, 02:34 PM   #4
Ed Wright
Ed Wright's Avatar
Like Tom said, both my Rossler and Pro Trans have the cooler fitting holes in the case plugged. Looped internally. Have not had a cooler for years.
Ed Wright 4156 SS/JA
Old 05-21-2013, 08:54 PM   #5
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Hello again Richie 2, I run a cooler on my BBC Th400 equipped Monza. It is a Long Mfr (i think) model that is the stacked plate design and I ordered a model that would accept the common 3/8" steel "brake line" type lines. i can dig up the part number if you are interested.
Tim H.
Kingston On.
Old 05-22-2013, 05:07 AM   #6
richie 2
no worrys tim thankyou. Toms suggested DERAIL units will work fine. they are very affordable from JEGS and have AN fittings for use with either a steel line or hyd. fittings. we're gonna' go with that.
Old 05-22-2013, 10:19 AM   #7
njk53
Tom is right. You probably don't need one. However, if you are like me, I like the extra insurance. I have a radiator with an in tank transmission cooler. I like the in tank type cooler because it will put heat the trans fluid quicker because the cooler gets washed with engine water/coolant. Also, the in tank cooler is more efficient than an external air to oil cooler by about 2 degrees F. We use a braided steel line from the radiator to the transmission with Jiffy-Tite Quick Connects at the transmission. The QC's are real convenient when you have to pull the motor or transmission. No mess.
Nelson Kowal
Stock 345
