What is the best type of fuel line to run from the pump up to the regulator, braided line, alum. hard line, etc? Thanks.
Liked 129 Times in 59 Posts
I've found the braided-line works best for me. The 1/2" aluminum that I used first was harder to bend properly, and difficult to secure to the chassis without deforming. Just my experience, but 20 minutes, two AN fittings and 6 insulated clamps drilled and screwed to the frame and I was done! And no pesky leaks either!
I also found a easy way to attach the fittings to the braided-hose. It's called a "Koul Tool", and it makes the job almost painless! ![]() http://www.koultools.com/ Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
lew do you have a good supplier for ( kool tool ) and part number. thanks jim
Liked 275 Times in 76 Posts
Look at the lightweight braided line, not the stainless braided stuff. Stay away from the hard lines, like aluminum. With vibration it will work harden the tubing and create potential cracking.
Sean
