Liked 121 Times in 11 Posts
How does the Chevy 350 " 70 2 barrel at 1686 X 1375 compare to the "72 2 barrel at 1686 X 1260?
Is there a significant difference? How about how much slower is the 2B to a 4B? Thanks.
Joe DeMarzo 1317 STK Last edited by Joe DeMarzo; 03-22-2013 at 09:48 PM. |
Liked 319 Times in 68 Posts
Joe, stick with the Q- Jet mileage won't be that much better with the 2 bbl. See you soon spring is coming I promise. Lee.
Lee Valentine 1661 STK |
Don't know about the 350 , but my 283 was a turtle with a 2bbl...
Everyone told me it would ,but i had to see for myself.......... One day wasted with that project.............
Danny Waters, Sr / 73 Duster "340" |
Joe, there's a pretty big difference between the 2bbl that NHRA "accepts" on the 70 and the 71-72 2bbl. There's also major differences in the 70 and 72 engines if that's what you're looking at.
Give or take about a tenth one way or the other, you'll slow down a second. Danny, the 2bbl that you had to use on the 283 is a small base 2g(same as my 307) and they're pretty horrible mainly because the top of the carb is so restricted. The 350s used a wide base 2g. There's one 283 stick Chevy II that did set a record with one though!
Liked 4 Times in 1 Post
I have two experiences with the "big" two barrel.
In 2004 we compared Q-Jet vs 2 bbl on our 255-350 that was set up for IHRA pure stock at the time. It was a stick shift, with the mandated stock valve spring pressure and stock duration cam. The 2 bbl slowed it about .55 and it was further under the index, by about .15. We didn't need a rev limiter for either combo, it couldn't spin high enough to hurt itself. Two years later, same car with a modern NHRA stocker engine and an automatic. This time the Q-Jet was further under the index by about .30 or more. As the difference between H/SA and M/SA is .70, this must mean it slowed 1.00 that day, although in my mind it was worse. The 2 bbl was going through the traps at 5700, the 4 bbl at around 7000+. Changing the gears and converter probably would have helped, but we decided not to pursue it any farther.
Tony Curcio 1860 STK |
I really think you guys are missing the point, Joe went from a big block to a small block then he read the post on cost per run and says to himself I have to go 2 bbl. I'll save on race gas. I'll be Angelo agrees with me.
