Old 02-28-2013, 10:34 AM   #1
njk53
Default QA1 Double Adjustable Shocks
Are any of you guys using a QA1 double adjustable front shock? Any Opinions? Comments?
Nelson Kowal
Stock 345
Old 02-28-2013, 01:45 PM   #2
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
Default Re: QA1 Double Adjustable Shocks
I have used them for 5 years and have had good experience.Biggest thing I found is not go too light on the sring rate as the shock gets the beating rather than spring. 50Lbs makes big diff. Also need to be careful adjusting and not turn/force adjusting knobs against the stops.
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
