Is .040 ok or should i put a thicker head gasket on it. zero deck motor.
Liked 505 Times in 116 Posts
Type of engine? Piston to wall clearance? Class?
68 Chevy11 327 F/S |
Piston weight ?
RPM ? Stroke length ? Steel or aluminum rod ? ! ! With 720 gram bare piston, I run .036" , to 7400... no issue.
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Liked 54 Times in 18 Posts
We ran .050 on a 68 Camaro Z/28 stocker back in the early 80s. Those were the stock piston rule days. We wouldnt have if we could have cut the valve reliefs
Liked 22 Times in 22 Posts
Plenty with steel rods, no matter the rpm.
don,t have one |
I don't have all the specs,but it's a 540 mopar with 4.500 bore and 4.250 stroke and uses a 7.100 steel oliver i-beam that i spin to almost 8000 rpm.
Liked 705 Times in 219 Posts
Are you talking deck height or piston to valve clearance? With a 4 speed, you need at least .080" intake and .100+ piston to valve on the exhausts. As far as deck height on that big of a motor, .045 total would be a real close call. Stuff stretches disproportionally at RPM, more so on a big inch long stroke motor. In fact, stuff you can get away with on a 283 won't work on a 350 without collision of parts. On small block stocker engines, we've run .028 total deck(block height and head gasket thickness combined), with .040 intake and .050 exhaust P to V with an automatic trans. I know, that's enough to make anybody nervous, it should.That's sometimes what it takes.
