For those of you running a 'Low' HP stocker (I thinking like ~250hp), what kind of short times are you getting? I am now at about 1.7 in the 60' with my new M&H tires, but my car is FWD. So, I'm interested to know how it compares to a RWD 'low' HP stocker. I know the higher HP cars are in the 1.4-1.5 range. But, It's probably not accurate to compare my car to that.
Rob Lloyd 3728 BF/S |
Rob, my current car (DF/S '92 Olds Toronado, 231 cid. 170/170hp) goes 1.90's in 60' (actually quicker than my old daily driven '95 Camaro LT-1 which had a 1.98 short time on a 13.88 @ 97 mph run). Olds was 1.95 on a 15.01, 89 mph pass at 3,500 pounds. I think the old BF/S turbo Sunbird (110 cid, 150/150 hp) I drove for Billy Nees went low 1.90's running 14.1's in the 1/4 at 2,600 pounds.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
My boy has a Aspen wagon that run N/O/P. It generally run Mid 1.5s
at O Weight (3650). It has run a Best of 1.498 at N Weight (3540) at Pomona last year. Small Valve Low Po 318 @ 230 HP. ProTrans made a ton of difference with straight cut Very LOW Gear! NOT inexpensive but it made a huge difference in performance and worth every penny!! |
Rob my car using the trans brake went mostly low 1.7's in decent air. Using the footbrake I slowed to low to mid 1.8's in good air.
When I put the 22" tires on low 1.9's are about as good as I've gone. Haven't tried them in real good air. With my car air makes a world of difference in the short times. The turbo might make up some air difference though. If I remember correctly I was 1.7's most of the time with the Turbo car.
Art Leong 2095 SS Last edited by art leong; 01-07-2013 at 07:03 PM. |
Liked 11 Times in 6 Posts
My E/PS 83 Camaro has 1.67's at 3240 lbs. I just got it this past fall and have not had much time to experiment, but I don't think there's much left in it.
C J McDonald |
Liked 244 Times in 26 Posts
Best 1.69 running 13.29 in r/sa. 3500 lbs c-10 pickup with 4.3 v6.
