Liked 7 Times in 6 Posts
Just put some Strange DA's on the rear and I have no idea what settings to use as a starting point. 70 Nova, ladder bar, 125 springs, 2900 lbs with 1320 on the rear. Calvert 90/10 with Santhuff springs with a loosened up stock front suspension.
What's a good starting point? Do you set the right shock a click stiffer on extension? I was told the rear suspension looked bound up, so I took the mono leaf set up off and put the coil overs on. The video shows where I was. |
Liked 13 Times in 11 Posts
What made you change to DAs? Was the car working with a single?
I went with DA's because I had to buy shocks to get coil overs and thought I might as well get the DA's.
The stock/super stock guys that saw the video said that the rear looked bound up and was not working at all. I wanted to lower the back of the car and get rid of the mono leaf/slider/floater set-up. |
Liked 1,985 Times in 598 Posts
Start loose. I have not found anything in rear shock adjustment. Now the front that's another story. That's where the DA shocks need to be.
Mike Pearson 2485 SS |
Start in the middle on both extension and compression. From there, tighten up the extension and see how that goes. If it's not going good, go the opposite. Once you find the happy spot, work the compression the same way.
Bad tracks need a loose extension (you are trying to work the slick harder to make up for the bad track). If your at a national event track surface, you have better bite on the track and you don't have to work the slick so hard. The compression adjustments are a fine tune. You don't want a situation were the extension is loose to help the slicks on a poor track and then the compression is also too loose. The slicks will hit the track hard and then bounce back into the body. Think all that through and you'll get it figured out. But the bottom line is you have to test. Nobody can tell you what adjustments you will have in the end as every component of your race car is different than the other guys. As far as staggering the adjustments, yes, you may find that helpful. Ideally, you should have a race car with no preload on one ladder bar over the other. You will find most have pre-load on the right (passenger side). If you can, make up for the launch issues with your shock adjustments (or spring rate and or height). You can even out a launch with staggered slick pressure but since you have better than average shocks, make them do the work so you aren't trying to remember what both slicks are supposed to be set at. FYI - I've found plenty of ET in rear shock adjustments from ladder bar cars to leaf sprung cars. I believe in quality shocks and they are well worth the money.
Jeff Lee 7494 D/S '70 AMX |
#6 | |
