Liked 20 Times in 15 Posts
my friend just finished a 496 BBC. had a solid lifter cam. not long after break-in a lobe failure occurred. he had the cam nitrided, so it would last a long time. there is a tech college near him and he had the cam and a lifter checked for hardness. the lifter came in about 54 RC and the cam between 34 and 39.
what we do not know is 1. what is a normal figure for these two pieces, and 2. should the cam be the same hardness as the lifter. any thoughts will be appreciated. thanks rod in AZ |
Liked 230 Times in 106 Posts
That sounds about right for lifters but, kinda soft for cam. How much spring pressure, open and seat? High Zinc oil correct? I'm guessing roller rockers?
Liked 232 Times in 39 Posts
Nitriding usually yields a hardness that you can't dig into with a 62 rockwell C file.
Marty Buth 3657 STK |
Liked 1,821 Times in 413 Posts
Where on the cam did they perform the Rockwell test?
Alan Roehrich 212A G/S |
One more question. Is it a Crane cam?
I assume the test was on the actual lobes, more than that i was not told. the brake-in was with the single outer spring. [dual spring pressure was in the area of 150 seat. personally i would have used a lower pressure for the brake-in, because the springs had to come off any but.....]
yes roller rockers and it was a lunati [sp] solid lifter. anyway the cam tested low on the rockwell. so Andy is really ticked off. thanks for the help. rod in AZ |
Should the cam and lifter be the same? No - never. If you want to see two metals eat each other up (cam to lifter, bearing to race, etc) just make them the same hardness. One of the two has to be a little softer.
Keep in mind that abrasive wear is the fastest growing type of wear you will see. Ever have a bearing go out in a rear end? It starts with a low growl, then just keeps getting louder and louder until it sounds like someone is running a bench grinder. That is a good example of abrasive wear. Once it starts, there is no reversing it. It just keeps getting worse and worse.
Chad Sheets | STK 319 | 10.69 | 1.39 |
MACH Development in Maricopa, AZ has a coating they apply to the cam & lifters that requires no cam / lifter break-in and you can start the engine first time with upwards of 520# spring pressure and let it idle if you want. I believe it's $150 total but contact them and find out for yourself.
Jeff Lee 7494 D/S '70 AMX |
