Old 09-20-2012, 04:02 PM   #1
FED 387
Liked 336 Times in 183 Posts
Question starter amp ???
anyone know off hand what the amperage draw is for a typical SBC mini starter---- not an OEM one but those Hitachi/Nippondenso motored ones that Jegs/Summit sells---thanx FED387
Old 09-20-2012, 10:17 PM   #2
John Dinkel
Liked 265 Times in 69 Posts
Default Re: starter amp ???
About 200-250
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 09-21-2012, 05:23 AM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Originally Posted by John Dinkel View Post
About 200-250
really?
that seems awful high for a gear reduction starter..
guess i'll have to check mine if and when it ever gets a battery hooked up to it.
Old 09-21-2012, 08:53 AM   #4
Bill Harris
Liked 26 Times in 13 Posts
Those starter are usually 1.4KW (around 1.9HP). At 746 Watt/HP, Mr Ohm sez that with a 12V battery it takes 116.67 Amps to dissipate 1400 Watts. That, of course is at 100% efficiency. If you assume a 70% efficiency the starter will draw about 152 Amps at rated output. The mini-starters use permanent magnets for the field so they draw a lot less current than the old style wound field (electromagnetic) starters which draw a lot of current just to create the static field.
Note the importance of having really good cabling and connections between the battery and the starter. If you drop voltage across the cabling, the amperage will go up quickly. If you only supply 10V to the starter due to drops or insufficient battery capacity, the amperage will go up to 182 Amps to get rated output from the starter. This is a vicious circle since as more current is drawn, more voltage is dropped across the resistive cables/connections so the voltage at the starter goes down, the current tries to go up.... and so on.... leading to the dreaded "click-----nothing".
Sorry for the lecture.. I'm bored....
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 09-21-2012, 10:29 AM   #5
FED 387
BILL---OK so based on your info what would be the smallest battery Amp hr or CCA or whatever would be needed to use this starter with a #6 cable with a maximum total length of about 48 inches probably closer to 36----all new stuff connectors ,cable , eye rings etc.---just trying to determine what is the smallest that will work satisfactorily-----can always get a larger battery if needed just trying to see what is the smallest for now-----any other suggestions you can make??--- is the battery/starter cable tthe correct size to big too small just right?? your thoughts please---yes,weight is a consideration here too---thanx FED387
Old 09-21-2012, 11:05 AM   #6
Run to Rund
Liked 56 Times in 29 Posts
I suggest you check on yellowbullet.com and look at the wire sizing chart:
http://www.yellowbullet.com/forum/sh...ad.php?t=47266
it looks llike 4 gauge would be better. I use 1 gauge for the 3' to my RobbMc mini starter from the junction block because too big won't hurt, and the junction is 24' from the battery (2/0 to the junction from the battery). Also, the initial surge needed may be a lot more than the running amps.
Old 09-25-2012, 06:17 PM   #7
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
16 volt lithium technology alllows for easier starting and much more stable voltage to supply ignition and pumps throughout the entire or multiple runs. They do not droop like a lead battery.
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
Old 09-25-2012, 08:16 PM   #8
Ed Wright
Ed Wright's Avatar
Fred, what do they sell for?
Ed Wright 4156 SS/JA
Old 09-26-2012, 10:11 AM   #9
Altronics
Sponsor
Altronics's Avatar
Our website www.altronicsinc.com has complete info and pricing.
THey start at $999 - includes charger.
Feel free to give me a call to discuss the correct battery for your application.
Fred Bartoli
847-923-0002
