Old 08-07-2012, 08:48 PM   #1
Grant Eldridge
Grant Eldridge's Avatar
Default BB Chev valve stem seal question....
I'm trying to source a small OD "rubber" umbrella style of valve stem seal that slips over a 3/8" diameter valve stem and just floats on the stem rather than being fixed to the guide boss. The issue is that I have valve springs with .770" ID so they need to be a smaller OD than the ones I've been able to locate, so that there will be no interference with the springs. These heads are on an assembled engine and have not been machined to accept the aftermarket pressed on types of seal. I'd like to get a part number, manufacturer or supplier that can supply these, or if anyone has some I can buy?
If you prefer to reply privately, you can also reach me at grant4060@yahoo.com, or by PM on this site, thanks!
Grant Eldridge is offline   Reply With Quote
Old 08-07-2012, 09:39 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: BB Chev valve stem seal question....
Grant,
If the guide boss has not been machined for a seal, then a small umbrella seal is probably not going to do you any good as it will not go over the guide at full lift. If it does not go over the guide it probably will not do much good.
That being said, the small umbrella seals made for Small Blocks will fit on a 3/8 stem. They are tight but they will work. I have used them on some tractor pulling 4 cylinders and have never seen one break. Not sure if they will fit inside the spring but I can measure one in the AM if you want.
Bill Koustenis
BillK is offline   Reply With Quote
Old 08-07-2012, 09:53 PM   #3
billy leber
Liked 10 Times in 1 Post
Pioneer 450 seals should work. They measure .750 o.d.
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC
billy leber is offline   Reply With Quote
Old 08-07-2012, 09:55 PM   #4
Grant Eldridge
Thanks, Bill, yes I'd appreciate that! Actually just needs a little oil control from oil running down the stem through the locks, the heads and valves are like new with no wear. The heads should have been set up for the press on seals when they were machined, but.... I had actually trimmed down a set of larger umbrella seals by cutting off the "umbrella" to clear the springs, but they looked pretty rough and I figured someone smarter than me on here would have a better idea. Please let me know, thanks!
Old 08-07-2012, 10:19 PM   #5
BillK
Grant,
The Pioneer OS450's that Billy mentioned are the ones I was thinking of. The brand really does not matter, any Small Block umbrella from the late 70's should be the same. Your machine shop should have them, I keep a box of 100 on the shelf
Another option is to just put a small block "O" ring on the stem below the retainer. I had a customer years ago that used them on his BB engines and claimed they worked pretty decent. I guess anything to keep the oil from running down the stem would help.
Bill Koustenis
Old 08-07-2012, 11:03 PM   #6
Tom Turner
If you use GM urethane on the top of the retainer to seal the locks you dont need a seal. The dissassembly of the spring / retainer combo is a little bit of a PIA but it works great.
Tom Turner is offline   Reply With Quote
Old 08-08-2012, 12:29 AM   #7
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Grant... I have used the small block o-rings on several different applications and found they work. Had situations with smokey start ups and they were enough to eliminate the problem.
MAURICE BLENDHEIM is offline   Reply With Quote
