Old 07-24-2012, 12:55 PM   #1
68Coupe
Default Question about going to a low 1st gear in a C4
I have a bracket car that runs 6.70's in the 1/8th with 1.43/1.44 60ft
The car has ladder bars/coil overs and i run a 28x10.5 bias slick weighs 3100lbs with driver
I am a huge fan of stock/super stock, especially the wheelstands.
When my car leaves it picks the front tires up about 8" and carries them out @20ft. I would like it to pick them up even higher
I was wondering if i put a low 1st gear in my C4 if it would make a big difference in how the car leaves. Also would it effect how the car runs.
68Coupe is offline   Reply With Quote
Old 07-24-2012, 02:48 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,954 Times in 590 Posts
Default Re: Question about going to a low 1st gear in a C4
its probably more the converter and the rear gear that will make the difference. Also how the engine is tuned. My powerglide has a 1.98 low gear and will get the wheels real high if I want it to. I am sure your C4 has a lower gear than that. The engine that I have in the car now actually likes a real tight shock setting and keep the front end down. Each combo will like something different.
Mike Pearson 2485 SS
Old 07-24-2012, 07:06 PM   #3
Mike Graham
Liked 341 Times in 67 Posts
I agree with Mr Pearson. It is more the converter than the low gear set. The stock c-4 has a 2.43 low gear. I run a SS/GT mustang with far less than the stock ratio and my car will drag the bumper without the front end tied down and 50 lbs of ballast on the front.
Mike Graham is offline   Reply With Quote
Old 07-24-2012, 07:19 PM   #4
68Coupe
so are you saying i need more converter?
Old 07-24-2012, 08:21 PM   #5
Chris1529
Liked 70 Times in 29 Posts
Also, if you put in a lower first gear, it will definately affect your converter. You will find you won't be able to leave at the same RPM. It will not stall as high after you install a low gear.
I would start with another converter too. What engine are you running now?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 07-24-2012, 08:41 PM   #6
68Coupe
running a 393W
Old 07-24-2012, 09:25 PM   #7
Mike Graham
There are too many unknowns to make a blanket statement.
Camshaft?
Heads?
Carb?
HP?
Old 07-24-2012, 10:30 PM   #8
Dick Butler
Liked 32 Times in 19 Posts
The more obvious question should be "Why do you want to pick the wheels up higher" It will slow you down, maybe make you more inconsistent, possibly cause a dangerous turn of the car???? If you want to improve the 60 ft or et then other things should be considered first.
Old 07-26-2012, 04:40 PM   #9
k.pascoe
Move your ladder bars to the top holes of the mounts if you what to stand it on the bumper.
That will move your instant center way high in front of the car. I promise you she'll wheel stand. 200 lbs. in the trunk won't hurt either.
k.pascoe is offline   Reply With Quote
Old 07-26-2012, 11:32 PM   #10
NewHemi
NewHemi's Avatar
Put in lighter front springs. That along with more weight further back should give more lift.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
