Old 07-17-2012, 02:53 PM   #1
Randall Klein
Liked 316 Times in 67 Posts
Default Head gasket ?
After popping a couple of engines this year, just trying to piece something together to finish season with whats left over. Question, with what I've got, is it better to have a gasket that fits the hole and is too thick, or perfect in thickness but a little too big for the bore?
265 SS 3.80 bore
I've checked with Cometic for a better match, but being a little cheap right now trying to patch the Nomad and '57 back together
Thanks in advance for any thoughts
Old 07-17-2012, 03:47 PM   #2
Liked 1,826 Times in 414 Posts
Default Re: Head gasket ?
You really do not want to alter the total deck clearance too much from the ideal.
That said, "too thick" and "too big for the bore" are too vague to allow a good answer.
Old 07-17-2012, 05:27 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Back in the late 90,s we set the record and had to take both heads off, when I went to put the motor back together I packed the generic BB gaskets in the trailer(4.250 bore) as opposed to the 4.100 396 steels I took off the car. Made first round and ran the same,left them on for the rest of the year. I would go with the bigger bore gasket (283?) than alter the deck with a thicker gasket. gsa612
Old 07-18-2012, 01:59 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
What he said
2009 V/SA Record Holder
Old 07-18-2012, 11:51 AM   #5
REGGIE WINKLES
Liked 39 Times in 9 Posts
Randall, you have a pm
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 07-18-2012, 09:06 PM   #6
Tom Meyer
Liked 354 Times in 120 Posts
Randy I have some 283 stuff, copper what do you need for thickness. I have my garage motor together yet if ron need something to run. Will be going thru Lincoln early fri morning .Tom
Tom Meyer 5240 SS Stock ???
Old 07-19-2012, 01:18 AM   #7
Jim Johnston/6022
Liked 13 Times in 6 Posts
Try a mr. Gasket mrg-57806 Bore is 3.870 .028 It is close and last time there was 2 gaskets in pack. for $40.
Jim Johnston/6022 is offline   Reply With Quote
Old 07-19-2012, 10:50 AM   #8
Tom Moock
Liked 10 Times in 6 Posts
Jim, Who sells mr. gasket 57806? Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 07-19-2012, 01:18 PM   #9
Jim Johnston/6022
If you look up MRG-5780 on summit it goes to MRG-5780G, the only difference i can see is the G has one gasket the other two, still half the price of a cometic.
Back to the 265, the gasket we have used for years and of course is no longer available is detroit gasket 55061hg for a 305 application.
Detroit sold to corteco (not to be confused with cometic) Corteco seems to have gone broke and or disappeared
Old 07-19-2012, 10:03 PM   #10
pmrphil
Liked 347 Times in 151 Posts
You might also look at Victor #5745 approx. 3.800 and .025 thick - I believe it's made for a 305 too.
Phil Molski
PMR Performance
S/C 1623
