Old 05-23-2012, 12:12 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Question Brake pressure switch
I would like to know what you guys are using for a brake pressure switch to use on a two step? I heard that there is one from a company called GEMS. But, I did not see anything in Grainger etc. If someone would recomend a switch and from where I would appreciate it. I heard that a brake pressure switch from a production car would work? I don't know if that is true. Any help would be appreciated.
Robert
Robert Simpson is offline   Reply With Quote
Old 05-23-2012, 01:52 PM   #2
Notch1320
Default Re: Brake pressure switch
http://classracer.com/classforum/sho...ressure+switch
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 05-23-2012, 02:19 PM   #3
Phillip marvetz
Phillip marvetz's Avatar
I bought mine from GEMS. The website is kind of goofy and there are alot of options on how you want the switch to be made.
2009 V/SA Record Holder
Old 05-23-2012, 04:53 PM   #4
1wayticket
Call Gary Stinnett, he sold me one.
1wayticket is offline   Reply With Quote
Old 05-23-2012, 06:41 PM   #5
Mile High
I've been using the one that came stock on my 64 Falcon. Screws into one of the ports on my linelock now that I'm using a non stock master cylinder. It's nonadjustable so I adjust reaction times with tire pressures.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 05-25-2012, 09:32 PM   #6
Todd Boyer
Liked 6 Times in 5 Posts
I haven't checked yet, but I've been told that a Volkswagen brake light switch (not sure what year) will work.
Old 05-25-2012, 11:11 PM   #7
Phillip marvetz
This is what I am using.
Gems PS61-35-2MNZ-A-FL18
P/N 2226644
Your needs and results may very.
Old 05-26-2012, 11:52 PM   #8
Robert Simpson
Question Re: Brake pressure switch
Notch1320, thank you for the info. I tried contacing the man you suggest but he said that I have to order the 10 min. So that will not work.
Phillip, where did you buy your GEMS switch from? I left a messsage with GEMS with no return yet. Any suggestions would be appreciated.
I have thought about the stock brake pressure switch but the ones I have found have a very low pressure on them? I might be wrong.
Thanks, please keep the ideas coming.
Robert
