Old 05-06-2012, 07:03 PM   #1
Mike Corbett
Default which is faster- VP C-11 or C12
Hey what has everyone had better luck with- VP C-11 or C-12 fuel. Just curious? Thanks for your input!
Mike Corbett is offline   Reply With Quote
Old 05-06-2012, 09:19 PM   #2
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Wink Re: which is faster- VP C-11 or C12
I just bought fuel a few days ago... wanted C11... only had C12.
He said that the C11 is for oval track racing with restrictor plates and up to 11:1 compression.
To me, that translates to a typical Stocker engine... often somewhat limited in optimum carb CFM, and modest compression ratio.... IE, cylinder pressures that are not right out there.
Sounds like C11 would be the fuel for most Stockers ?
But damn, this stuff can be hard to get around here.
If your'e under an actual 10.5:1... I'd suspect the C11 would be more efficient.
BTW, I'm no whare near the xpertise level of some of the guys here, but I DO tune...
so don't take me as the gospel... but just a few words from it
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 05-06-2012, 10:09 PM   #3
Liked 1,924 Times in 432 Posts
Default Re: which is faster- VP C-11 or C12
What makes the most HP depends entirely upon the combination. Also, to get the most out of a particular fuel, you have to do a ton of carburetor and timing tuning. There is no easy cut and dried answer. Every combination is different, and some carburetors, if you run a carburetor, do not tune easily, and may be near impossible to get tuned to a particular fuel.
Personally, I hate C11, it always left out fuel systems filthy. I got better performance from C12, but passing fuel check was hit or miss. The price of VP fuel is absurd, considering you may get a batch that fails fuel check 2-3 times more often than it passes.
Old 05-06-2012, 10:20 PM   #4
Aubrey N Bruneau
excellent, Alan !
I'm about to trailer 750 miles one way, to the only race I'll be able to attend, with $210.00 of fuel, that probably won't pass for qualifying ?
ah yes, this is getting better and better !
Interesting about tyhe C11. Good to know.
Old 05-06-2012, 10:27 PM   #5
Aubrey, the best advice I can give you with C12 is to NEVER, under ANY circumstances, allow it to be exposed to the atmosphere for long periods of time. keep it sealed up in any container you have it in. Take your jugs and turn them upside down. If they leak, either fix the leak or replace the jug. Either drain your fuel cell, or seal all the vents. If you buy it by the drum, keep the drum sealed with the bungs, and use bung wrenches.
I should, in the interest of fairness and honesty, disclose that we do not use VP C12 anymore, we're on the Sunoco program now, we use Sunoco Supreme.
Old 05-06-2012, 11:24 PM   #6
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
X2 on the Sunoco never had a problem.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-06-2012, 10:32 PM   #7
7423
9.5-1 5.0 Ford. Arco 91 octane is .05 quicker than any legal race gas I have tried. Its a shame some of us have to buy something that we really don't need.
7423 is offline   Reply With Quote
Old 05-07-2012, 11:50 AM   #8
Mike Croley
Originally Posted by Aubrey N Bruneau View Post
excellent, Alan !
Let me make a suggestion Aubrey . As of the beginning of the year , Renegade Racing Fuels are NHRA and IHRA legal . Contact them and see if they have any dealers near you . Renegade will get you the same or better performance than you have now at a lot less money . If they don't currently have a dealer in your area , I imagine it would be well worth your while to talk to them and see about becoming a dealer . Or if you know of a shop that would be a good candidate to sell race gas , have them contact Renegade .
I know race fuel is difficult in Canada at the moment , so this would be an ideal time to make a move .
Mike Croley is offline   Reply With Quote
