Liked 20 Times in 15 Posts
sometime back i posted about shortening a pin. this is a forged TRW piston with a 3" Chevy pin.
what i want to do is place 2 .042" Tru-Arc lock rings on each side of the piston. i have now done some serious measuring and i find that there, for whatever reason, is a large amount of end play between the pin and the OEM single lock ring groove, .029" to be exact. so, if i widen the original groove to the outside by .0275" i can get the 4 lock rings in, and not have to shorten the pin. this leads to a whole new question. there will be approx. .0875" of material remaining between the outside of the lock ring and the flat face area [on the outside] of the piston. the question then , is .0875" enough material to hold the ring in place and not be hammered out? currently, in unmodified form there is .111" of material. .111"-.0275" = .0875" thanks rod in AZ |
Liked 1,821 Times in 413 Posts
Avoid using Tru-Arc retainers if at all possible. There is a very good reason that people use either round wire retainers or double spiro-locs, and it is not because Tru-Arc retainers are real reliable. Those things are "okay" at best for a stock rebuild, in a restored car that won't be driven a lot. In a modern race or high performance engine, they are a recipe/invitation for disaster.
Alan Roehrich 212A G/S |
Is a pressed pin out of the question, or maybe nylon buttons...?
Chad Sheets | STK 319 | 10.69 | 1.39 |
