Old 03-21-2012, 07:58 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Default Battery Cut-Off
Can you put in a battery cut-off switch under the hood if your only using 1 battery ??
I do not have 1 in the trunk.
For Stock Elim.
Thx
Old 03-21-2012, 08:22 PM   #2
art leong
Default Re: Battery Cut-Off
For Stock Elim.
Thx
If you did not relocate the battery a switch is not needed. But you can run one if you want.
My battery is in the stock location. But I have a fuel pump cut off coming out of the tail light.
It's a fuel injected car, so once you hit the switch the engine shuts off.
Art Leong 2095 SS
Old 03-21-2012, 09:46 PM   #3
Doug Blackley
Doug Blackley's Avatar
Pete, I use the Moroso shut off that goes right on the battery post. I always shut it off when done for the day or between races, I consider it good insurance.
Doug Blackley 1697 STK
Old 03-21-2012, 10:10 PM   #4
pmrphil
Liked 393 Times in 153 Posts
Pete -
If you do use a battery switch make sure the amp rating is high enough so you don't burn up your starter - I've seen the cheaper ones that will only carry 400 amps.
Phil Molski
PMR Performance
S/C 1623
Old 03-22-2012, 01:58 AM   #5
Phillip marvetz
Phillip marvetz's Avatar
Originally Posted by doug blackley View Post
pete, i use the moroso shut off that goes right on the battery post. I always shut it off when done for the day or between races, i consider it good insurance.
x2
2009 V/SA Record Holder
Old 03-22-2012, 12:31 PM   #6
SCOTT SST2871
I have a similar question for stk elim.what if the battery came from the factory in the trunk(2008 pont g5)would they enforce having a cutoff switch
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 03-22-2012, 04:16 PM   #7
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
x3
Bob Bender 144 O/SA
Old 03-22-2012, 06:22 PM   #8
Pistol Pete
Thx for the replys.
