Old 03-17-2012, 06:03 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default ATI damper bolts loosened
A new ATI damper installed on 496 BBC. Damper fits tight on the crank and damper retainer bolt is tight.
There are no indications of any problems.
However, the damper assembly bolts are all loose, one bolt completely out laying in the engine catch pan.
Anyone have this happen? Loctite the bolt and watch closely? Other suggestions?
PS, engine feels smooth. There is no usual feel or vibration.
Larry Woodfin 471W
Old 03-17-2012, 06:34 PM   #2
Dragsinger
Default Re: ATI damper bolts loosened
I think I see the problem. I did not realize the three pulley bolts must be installed, even if you are not running a pulley.
Maybe I have any easy fix.
Larry Woodfin 471W
Old 03-17-2012, 10:28 PM   #3
Ed Wright
Ed Wright's Avatar
Read the instructions, Larry. LOL blue LocTite and torque'em.
Ed Wright 4156 SS/JA
Old 03-18-2012, 07:52 AM   #4
richie 2
Liked 205 Times in 93 Posts
after install you could scribe a line across them and visually check periodicly to see that it's still lines up across the fastener.
