1. Coan XLT 350 ultimate spragless, deep pan, trans brake, 3speed Gears 2.27-148-1-1. Freshened last year very few runs $4600 or offer
2. Precision 3 speed shifter with air shift. $350 3. Co2 shifter kit with 2 bottles $125. 4. 7 inch and 8 inch converter with PG spline make offer 5. Biondo RPM shift controller for 3 speed air shifter $100 6. 15x14 Bogart wheels chev bolt pattern 4 and 1/4 inch backspacing with 31.25x12.2x15 M/T radials $700 will separate 7. Ford 9 inch 5.63 richmond pro gear used very little $200 8. Factory 396 375 HP Alum intake #163 last 3 $210 9. 15x8 1/2 centerline warrior wheel like new 3 1/2 backspacing $300 10. 12 bolt chev 4 link rear end housing set up for 4 link, coil overshocks, comp. engineering wheelie bars, S&W brackets, 33 spine Moser axles with moser c-clip adapters, 12 bolt moser spool,& S&W brackets width 42 3/4 inch axle face to axle face. Make offer 11. Holley blue fuel pump $65 12. JE 396 375 hp NHRA legal 30 over pistons used very little $300 13. Dedenbear RTD6 delay box $110 14. MSD 6400 ignition box $90 15. 8 gallon plastic fuel cell $45 16. Edelbrock small block chev alum. waterpump make offer Don Duke location Iowa Cell 515-480-6046 |
