Old 03-07-2012, 04:45 PM   #1
JA ENGINES
Default weldon fuel pump info or experience
need info on a weldon fuel pump i have a bg 400 now it pumps 350gph the one weldon sent to me is only rated at 150-180gph. everyone i know that has this in their car has a dragster has anyone ever use this in a door car with the tank in the trunk. did anyone ever volume check it after the regulator ? how many sec to pump a gallon after the regulator
JA ENGINES is offline   Reply With Quote
Old 03-07-2012, 05:10 PM   #2
FINESPLINE
FINESPLINE's Avatar
Default Re: weldon fuel pump info or experience
How are you doing Junior ! Congrats on the Division 1 SS Championship. Give my regards to your dad for his election as a Hall of Famer. ----------You have to put more info out there concerning the exact model # etc. of the pump from Weldon. These people are glad to help.--------John
FINESPLINE is offline   Reply With Quote
Old 03-07-2012, 05:25 PM   #3
FINESPLINE
FINESPLINE's Avatar
Junior, You might be better off moving your questions to the S/SS tech forum . Just trying to help. Been busy with the mild winter . Will try to get down to the shop to see everyone. Give my regards.---John
Old 03-07-2012, 05:35 PM   #4
BlueOval Ralph
Banned
How much HP is your engine making? at 150 gph thats 900 lbs per hour
at 180 gph thats 1080 lbs per hour
using 6.00 lbs per gal
BlueOval Ralph is offline   Reply With Quote
Old 03-07-2012, 05:53 PM   #5
Jeff Beckman
Jeff Beckman's Avatar
Send a message via AIM to Jeff Beckman
You should call Jim Craig at Weldon, or write to him here on this forum. He works at Weldon and knows more about there products than anyone. I run one in my Super Gas car with cell in the back feeding 1050HP it works great, I have been thru 2/3 BG 400 and would always have a big fuel presure drop. None with Weldon. It works very well for me and I can not say enough good about Jim/Weldon.
Jeff Beckman 318J ET, SG
318T SC
Jeff Beckman is offline   Reply With Quote
