Old 02-22-2012, 01:01 PM   #1
vetteboy
Liked 2 Times in 2 Posts
Default Quick time bell housing question.
I have a quick time bell housing and have problems getting it parallel to the block. I have .004 run out right know, is that close enough? I have had the bell housing ground flat. Do you guys then shim the bell housing to the block or do you somehow machine the block perpendicular to the crankshaft. Thank Brett
vetteboy is offline   Reply With Quote
Old 02-22-2012, 02:22 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Quick time bell housing question.
From what you are describing, it sounds as though you are checking the bellhousing parallel to the block? Have you verified the register bore? That is the measurement that is critical as well.
This is an article from Lakewood, and will be the same for any bellhousing.
The .004 could be paint on the block, bolts not torqued the same as well. More information is required.
http://www.gt40s.com/forum/attachmen...1&d=1292251774
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-22-2012, 10:14 PM   #3
vetteboy
Yes I was talking about the parallelism to the block. I have sanded all the paint off the block and have no interference in any of the bolt holes. i had the block linebored. I just want to get everything as close as possible.
Brett
Old 02-22-2012, 11:19 PM   #4
Chad Rhodes
Brett
Contact scott at south land. They have been having to machine them back to parallel
Chad Rhodes 2113 I/SA
Old 02-23-2012, 08:30 AM   #5
tj310
We have one bellhousing that I put a .060 shim on the top left side. This trick worked on at least two diff blocks. I used to dial both round and flat. GM also recommends dissambly of the trans, bolt on the empty case and dial in the rear bearing register using shims between trans and bell to correct.---Trevor
Old 02-23-2012, 11:02 AM   #6
Run to Rund
Liked 55 Times in 28 Posts
I have ground the block plate before--cheaper to replace later if another block is used in the future. .004 is probably OK because of the distance from the pilot bearing, assuming you are measuring at the bolt areas. Also you can change the order and tightness of the bolts in their sequence to see if the measurement changes.
