Liked 99 Times in 60 Posts
Please tell me about your front spring choices. Is there an after market vendor/manufacture who custom builds accurate spring choices?
Specifically, factory style front springs as used on stock/super stock racers. Also, is there a "home method" to measure rate of a factory type spring?
Larry Woodfin 471W |
Liked 46 Times in 29 Posts
I have Santhuff. Problem is you have to cut a complete coil off for the to fit into factory lower control arms as the are machined flat on both end of their springs. I am not comfortable with the flat side not sitting flush in the lower control arm spring pocket and do not want any cutting or abrasions that might lead to a cracked arm some day.
Chris. |
Banned
Call Eaton springs in Detroit
