Old 12-20-2011, 01:46 PM   #1
eddie c
Default What to do with my good? SBC engine block!
A couple of years ago I purchased a 1969 Corvette shortblock, its a a 350ci /350hp 4bolt main motor. Upon disassembling the block I found where a wrist pin came loose and put a good scratch up and down the cyl bore. The scratch was to deep to come out in a rebore so the
machinist suggested our only option was to
sleeve the block. The block has been sitting for a few years without
any other work being done on it. I am now considering starting to
gather parts for it and having a stock elim. 350 /255 hp engine built .
My question, if everything else checks out ok on the block, would you consider this a good canidate to build or should I start looking
for a block that has not been sleeved? ed
eddie c is offline   Reply With Quote
Old 12-20-2011, 02:10 PM   #2
Liked 1,826 Times in 414 Posts
Default Re: What to do with my good? SBC engine block!
There is nothing wrong with a properly installed good quality sleeve. We race sleeved blocks.
However, I strongly suggest you invest in a new Dart block. The cost is much lower than fully prepping a production block, and the Dart block is stronger, it will last longer and make more power.
Old 12-20-2011, 03:08 PM   #3
Lambertcars
I have a bowtie block in my Super Stock 68 Camaro and it has 2 sleeves and it runs fine, I was not going to discard a bowtie block just because 2 cylinders needed sleeves. I hope this will help.
Allen
Lambertcars is offline   Reply With Quote
Old 12-21-2011, 03:36 PM   #4
Woodro Josey
Liked 3 Times in 1 Post
Eddie, find someone with a sonic tester and have that done, it will tell you if that 4 bolt block is thick enough to build a class motor out of. It is very, very hard to find a production block, that is thick enough to build. Both Alan and Allen are correct in what they are saying also!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 12-21-2011, 05:29 PM   #5
eddie c
Thanks to all that responded. ed
Old 12-22-2011, 09:33 PM   #6
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: What to do with my good? SBC engine block!
Dart block.I just got mine back from Gregg Luneack. Can't wait to assemble this thing and see it run again.Has to be faster than the production block.
