Liked 7 Times in 5 Posts
2010 Mustang ---- 67 Camaro
2.08/160 valves 194/150 valves 5.12/5.12 cam lift 3.90/410 cam lift roller cam hyd. flat cam 1.62 rockers 1.50 rockers 56cc heads 62cc fuel injected Qjet not sure on pushrods ?? NHRA/ 295 hp NHRA/290 hp both run E/SA Last edited by Mike Savelle; 12-04-2011 at 08:57 AM. Reason: addition |
Liked 203 Times in 52 Posts
Nope perfectly normal ,did you not click the NOS bottle factory installed on the Camaro???I saw them on paper LOL
Kevin |
Liked 36 Times in 26 Posts
I got a question about the ford cam lift. Is this on the pushrod side? Or is this a SOHC/DOHC? If it has pushrods, that means the theoretical valve lift would be .829 inches. Am I seeing some thing the wrong way. THAT IS A LOT OF VALVE LIFT TO ME.
What is the difference in the cubic inches of the engines?
ed ![]() |
Liked 174 Times in 39 Posts
2010 Mustang- 352
1967 Camaro- 350 You forgot the mustang's better heads, intake, and throttle body as well. It has the potential for 9 second runs.
3207 D/SA, C/ED |
#6 | |
engine size. I thought it might have been a 4.7 liter motor. I have been out of competition for several years,but there were many similarities between then and now. Unfortunately the small block Chevy has been raced and developed over several years,so currently, the Chevy is much closer to its full potential then the Ford.If someone races this Ford combination next season and gets everything right,hopefully NHRA will re factor the motor. |
#7 | |
3207 D/SA, C/ED |
