Liked 140 Times in 51 Posts
I have a 66 Chevelle that i am looking for a 12 bolt for and was told the 66/67 is different than the 68/72 .No body seems to know why.Can anyone on here shine some light on this.Thanks in advance
Kevin |
Liked 39 Times in 9 Posts
I've swaped 12 bolts from a 69 to a 67 with no problems on either car.
Reggie Winkles 2650/Stock |
Liked 783 Times in 195 Posts
'65-'66 & early '67 are shorter than the later rear ends. Spring seats are different is some of those years, too.
Liked 54 Times in 27 Posts
The later unit is about 3/8" per side wider. Spring mounts are flat plates on the early one, using a formed steel top cup and a 7/16" bolt to hold the spring. 68-up use a small "tower" as a seat and the spring pigtail simply plugs into it.
