Liked 816 Times in 215 Posts
Does anybody know where you can buy the Black n White Checkered Flooring for the
inside of a trailer ???? Also, Is it expensive to do ?? Thx |
Liked 6 Times in 4 Posts
You can get vinyl flooring (black and white checkered) at any of the "big" home improvement stores..... Not very expensive....
Not hard at all to install, especially if you have a clean, oil free, floor, for the vinyl adhesive to stick to...... The down sides that I have found with the vinyl floor covering (black and white checkered) in my trailer is, it stains from many of the normal, automotive fluids, and it "nicks" relatively easily. |
Liked 138 Times in 51 Posts
There are different grades and different prices to go with them. However, I don't know how the home improvement vinyl flooring compares to what the trailer companies use in their trailers. I would imagine that it is an "industrial grade" and is more durable.
I put diamond plate rectangles on the vinyl flooring big enough to cover the general area where the race car tires sit. It will discolor and wear otherwise. My vinyl floors have a dark "marbled" pattern which helps "camoflage" any potential stains. |
http://compare.ebay.com/like/1905858...Types&var=sbar
I would go with marble as the checkerd board is very time consuming to keep looking good from my experince Ray Fordyce
Fordyce Motorsports SC 1538 / SC 153R |
