Old 07-06-2011, 01:22 PM   #1
my69396
Liked 46 Times in 20 Posts
Default Auto vs Stick
If a car is going 10.80 at 124 with a stick what would be the et and mph with a auto? Any ideas, I know that there is some factors to consider but if you took the stick out and put in a quality auto what would the difference be?
my69396 is offline   Reply With Quote
Old 07-06-2011, 03:20 PM   #2
Bret Kepner
Bret Kepner's Avatar
Liked 11 Times in 2 Posts
Default Re: Auto vs Stick
It depends more on the abilities of the manual driver than the switch of transmissions.
Bret Kepner
BRETKEPNER@Prodigy.net
Saint Louis, Missouri, USA
Bret Kepner is offline   Reply With Quote
Old 07-06-2011, 03:26 PM   #3
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
It depends on how much your converter is slipping if everything is equal,like rear end gear ,tire size and abilities of the manual driver.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 07-06-2011, 04:49 PM   #4
SuperStockDodge
SuperStockDodge's Avatar
Well, you will probably lose some manly hood as well as a couple MPH with switching to a slush pump-I mean automatic... lol
Sean Fischer 5864 SS/E
SuperStockDodge is offline   Reply With Quote
Old 07-06-2011, 05:06 PM   #5
It depends a great deal on the combination.
Old 07-06-2011, 08:08 PM   #6
Rory McNeil
In addition to overall combination, some automatics are more efficent than others. In my bracket car, with a mild 428FE Ford engine, and a fairly good C6 (low drag Torrington bearings thru out, Art Carr trans brake, 8" converter etc) the best the car went with the C6 was 10.55ET @126 MPH. With no other changes, other than replacing the C6 with a 4 speed Jerico & McLeod Soft Lok clutch, the car has gone a best of 10.03@132mph.
NHRA 6390 STK
M/S 85 Mustang
Old 07-07-2011, 01:54 AM   #7
Phillip marvetz
Phillip marvetz's Avatar
Just to show how wide a range this question encompasses I race the same track as Rory and went the opposite direction, 14.00 with a stick and 12.80 with a auto. It all depends on the combination.
2009 V/SA Record Holder
Old 07-07-2011, 03:12 AM   #8
Jeff Lee
Jeff Lee's Avatar
ET will vary because there are so many variables. But MPH should almost always be better with a stick.
Remember, MPH is based off HP. ET is everything else that is involved with getting you from point A to point B.
Jeff Lee 7494 D/S '70 AMX
