Old 03-04-2011, 04:17 PM   #1
wayne hutton
Default what to use to clean trailer
hey guys whats the best product to clean and maintain a .050 wall trailer, I read on here sometime back a post giving discriptions of the correct products to use and not to use some stuff, may even damage the finish. I have had problems in the past by steaking the polished stuff in the process of trying to clean the exterior and also the extruded alum floors seem to discolor real easy what should be used on them.
just bought a used ATC 32' and it needs a good overall cleanup just dont want mess up more than i fix.
thanks in advance for your help
wayne hutton
wayne hutton is offline   Reply With Quote
Old 03-04-2011, 04:37 PM   #2
Dion Hildebrandt
Dion Hildebrandt's Avatar
Default Re: what to use to clean trailer
believe it or not ,nothing gets your whites whiter than 'sunlight' powdered laundry soap. We use it as a car wash soap at the body shop and it does a wonderful job on white paint jobs on fleet trucks which are used in the fields. it does not damage the finish as long as proper washing techniques are used.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 03-04-2011, 05:32 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 866 Times in 235 Posts
Don't use any products using butyl esters such as Spray9 or Greased Lightning . They will streak and discolor the panels.
Strong laundry detergent and elbow grease work best.
Dions' correct ,It really works well for body work,strips wax and silicone right off!
Dave Riberio had a product he was selling , RV5000 ? I think.
That worked really well.
Old 03-04-2011, 05:41 PM   #4
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: what to use to clean trailer
Simple Green and about 5 illegal aliens should do the trick.:>):>)
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-04-2011, 06:45 PM   #5
Joe Hertline
Liked 3 Times in 2 Posts
Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
Scotchbrite works well on the aluminum floor...all you need is a case of that, a sanding block, and a free weekend. After that initial scrub, there are aluminum waxes that make it easier to restore the shine - make sure you wipe up any water or fluid that might hit the floor and it'll last for a while.
Joe Hertline 1318 SS/FA
Joe Hertline is offline   Reply With Quote
Old 03-04-2011, 07:51 PM   #6
FED 387
Liked 332 Times in 180 Posts
Ditto on Simple Green do it in the shade and start at the top and work your way down---Get it at Wal mart for about $8 a gallon--its cheap and effective & it works well
Old 03-05-2011, 10:14 PM   #7
68camaroSS
[QUOTE=Joe Hertline;243895]Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
X2 on that for black streak removers. They will take off the black streaks, but wait to you see what it does to your shiny aluminum trim, it spots and tarnishes them, and I followed the directions. Learned my lesson the hard way.
68camaroSS is offline   Reply With Quote
Old 03-04-2011, 06:36 PM   #8
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Dave had RV455. It did work pretty good too.
2894 STK
Old 03-04-2011, 10:23 PM   #9
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
yep rv455 that makes trailers white again,use it in a spray bottle then wipe and hose gmonde
Old 03-04-2011, 05:18 PM   #10
Robbie Draughon
Liked 29 Times in 5 Posts
Jax Wax citrus cleaner. It's the best thing I've ever seen for making a trailer look like new.
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
