Old 01-02-2011, 04:52 PM   #1
firebird
Question modified stock clarity
i have some questions on building a modified stock motor. i am looking at a b or c class and i am not clear on carburetor or a few other items. i also don't understand the cylinder head rule. pistons are another question. will somebody give me a little clarity on building a modified stock engine thank you.
firebird is offline   Reply With Quote
Old 01-02-2011, 08:58 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: modified stock clarity
750 cfm carb you can check the list for legal carbs . heads and block need an o.e. casting number. aluminum in b , iron in c. if it's a chevy combo . most in b use either a 15 or 18 degree gm, but the sb2.2 head is also legal. c guys use the iron vortec heads most often.must be an inline valve head only. as far as pistons, pretty much anything goes.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-02-2011, 09:24 PM   #3
firebird
thanks mark----I feel like you need a lawyer to understand the NHRA rule book ----mistakes are expensive
Old 01-03-2011, 12:30 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Legal carbs & Bore size by NHRA:
CLASSES
750 CFM
SS/BS, SS/CS, SS/DS,SS/TB, SS/TC, SS/TD, C/ED, ASR,
A/SR, B/SR, C/SR, B/EA, C/EA. D/EA, E/SM, G/SM.
CARB # PRI TB SEC TB PRI VEN SEC VEN
3310 1.687 1.687 1.402 1.463
4779 1.687 1.687 1.402 1.402
6109 1.687 1.687 1.402 1.402
6709 1.500 1.750 1.276 1.588
8156 1.687 1.687 1.402 1.402
9379 1.687 1.687 1.402 1.402
9645 1.687 1.687 1.402 1.402
Adger Smith (Former SS)
Old 01-03-2011, 11:18 PM   #5
340Cuda
Liked 805 Times in 341 Posts
CLASSES
750 CFM
Which one do most folks run these days?
Bill
Old 01-04-2011, 10:19 AM   #6
Mark Markow
Bill
most use the 4779 holley but barry grant makes a demon that is also legal. i'm using one. it works well out of the box. it's good place to start without having to send your holley out to someone for mods.
Mark Markow
171 ss/tb
