Old 06-02-2007, 02:31 PM   #1
Scott Lucky Hudson
Default supergas front end travel question
I had limiting straps on the from of my car that were made from nylon. They worked great for about a year and then started to stretch. My suspension was set up for about one inch of travel and then it went to 2 inches.
So i changed it and used chains instead.
Now I have more adjustability also.
My question is:
What is the best amount of travel and would no travel be a bad thing?
I wanted to try it with zero travel and see how it worked.
Visit www.speedsceneracing.com for a free Net TV show dedicated to the sportsman racer.
Scott Lucky Hudson is offline   Reply With Quote
Old 06-07-2007, 12:25 PM   #2
Scott Lucky Hudson
Default
100 views and nobody has any input?
Is this a stupid question to ask?
Old 06-07-2007, 02:42 PM   #3
GaryGoFast
Default
I have to assume that you are attempting to hit a .400 pro tree, I would adjust til the car goes red or the tires start to spin, without more input , very generic answer.
gary
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 06-07-2007, 03:26 PM   #4
Dave Steltz
Dave Steltz's Avatar
Default
Scott, I dont think that there is a "right " answer...on my car I have it tied down to about 3/4"...I know some guys that had their's tied down to less than 1/4 inch....but my experience is that the difference between 1/2 and 3/4 of an inch in travel wont make a noticable difference....
With my car it was more noticable when I raised or lowered rear tire pressures and leave rpm's...for a .400 tree I try to leave 200 rpm below stall and I have raised tire pressure as much as possible to eliminate sidewall wrap...
Dave
Bad Dad Racing SG 1359
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 06-07-2007, 08:34 PM   #5
Bryan Gillespie
Banned
Default
What up my NY. buddys
Bryan
s/g & s/p 120
s/st & s/c 1219
Bryan Gillespie is offline   Reply With Quote
Old 06-07-2007, 08:36 PM   #6
Scott Lucky Hudson
Default
Thanks, i guess i need to try different stuff. Thanks for the help, yes, a .400 tree.
I will start at 3/4 to 1 inch and see how that works.
Old 06-07-2007, 09:15 PM   #7
Dave Steltz
Default
Scott, one more thing to try if you can...if you have any adjustments for your front shocks stiffen them as much as possible, you want the extension as slow as possible..
Another thing that has not seemed to make any difference is tire pressure, anything over 40 lbs didnt make a change....I'm assuming that you have 23 or 24 inch tires, if not see if you can put a short one on it...
Yo B-Man...Your signature should be saying
SST
SG/SC
Top Sportsman
Dave
BIAECH Racing Team
Old 06-08-2007, 09:28 AM   #8
sg1838
Default
Scott,
I never saw your post until today, but do NOT, under ANY circumstances go with 0" of travel. I use a chain also, and did that once to see what it would do, and what it does is bump steer like crazy! With my chain setup, my choices were either 0" or 1" (or more). 1" of travel worked fine, so that's what I ran in the car for years.
Just don't do zero...you won't like it (unless maybe you're a thrill seeker, then maybe you will like it...)
Jason Oldfield
S/G & S/ST 1838
sg1838 is offline   Reply With Quote
Old 06-08-2007, 04:34 PM   #9
Bryan Gillespie
Banned
Default
Yo Dave the said comp car owner wanted to run the ATCO race, then he will he will pull out 1260 h.p. motor & install 1140 h.p. motor bring it to cecil co. and make a pass, if it goes 7.40 anything I will buy it on the spot. so until then.
Bryan
s/g & s/p 120
s/st & s/c 1219
