Liked 372 Times in 130 Posts
When building a crate engine, do I need to use the exact camshaft part number listed on the tech sheet in the engine build, or can I have a custom grind made with the same lift specs as stated on the tech sheet ? (with any duration)
Thanks
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 880 Times in 311 Posts
Get a custom grind. I've used both B & C brands from the Memphis area. Actual lift at the valve is all that is checked. Another tip: What ever brand rockers you use make sure they are not stamped with the ratio.
Adger Smith (Former SS) |
